RE: DA 50 problems
After reading the last posts I've got to agree with the battery being the issue. It now appears I had the reason for the pooling in the reed valve incorrect. My apologies
I'm wondering if the battery is capable of taking the load. You might want to load test it but keep the load on it for a little while longer to see what the voltage does.
There is also the outside possibility the ignition has an issue.
