RCU Forums - View Single Post - engine cleaning
Old 03-28-2006 | 11:26 AM
SManMTB's Avatar
SManMTB
Default RE: engine cleaning
ORIGINAL: p0u1burke
Just remove it from the car and clean it. Open it up and check if the piston/liner is worn out.
If the piston can be pushed above the top of the liner it is most likely worn out.
People on the board doesn't have X-Ray vision so you do need to put some effort in.
Besides do the normal maintenance routine:
- Use clean airfilters
- Check fuel and pressure lines for leaks
- Check fuel filter and clean it if needed.
- Check servo linkage, does it open the carb 100% ?
- Check clutch shoes and springs on a regular basis.
- Clean the car at least every other day of running. I know fail doing this frm time to time.
