ORIGINAL: tiktock
once i took the spark plug out to see why the engine wasn't starting. the plug was dry, but there was no spark. i rinsed it with gas and still no spark, about 10 mins after rinsing it the spark plug started working.
In my estimation, this is the key to diagnosing the problem. This is exactly the problem I had, pull the plug and there was no spark until it had sat for 10 or 15 minutes, then it would start sparking again.
I couldn't say why Nogyro is having the problem he's got, but once I got the faulty ignition replaced the engine will start anytime you want to try it. My new ZDZ-100 is the same way, cold, hot or just warm it will still start...
