RCU Forums - View Single Post - Engines
Thread: Engines
Old 03-29-2006 | 12:42 AM
sh0wtime's Avatar
sh0wtime
Default RE: Engines
the compression Ratio is the same but in reality you will probably get higher cylider pressure with a non pull-start engine once you factor out losing crankcase compression through the one-way bearing
bump start all the way
