RE: E-flite Ultimate FX
Thanks Ion.... but you don't have to go through the trouble. I appreciate it.
I took the rest of the stick mount embedded behind the firewall out. I was planning on inserting another stick in the same position since the indentation in the fuse for the stick mount seems to be cocked for proper thrust.
Do you think I should try to experiment with a little up/down thrust to fix the "Nosing Over" issue. If so, should I add some "Up" thrust with the stick cocked a little upward?
I've never dealt with thrust adjustments, so if I got it backwards... let me know. I just want to fix the rocking motion and the nosing over issue.
Thanks again.
Mark
