RCU Forums - View Single Post - Brillelli 25GT on CMP Spitfire
Old 03-29-2006 | 09:49 AM
Zippi's Avatar
Zippi
My Feedback: (10)
Default RE: Brillelli 25GT on CMP Spitfire
On the Giles 202 there is a hole in the engine box where the fuel tank sticks out the front. Once you bolt the 25cc GT engine on, how would you route the fuel lines since the engine would block everything? If some sort of stand-off mount is used to set the engine away from the engine box and give the fuel lines access to the engine, do you think the distance from the engine box to the backplate would still be ok to mount the cowl correctly?
