RE: Biplane Aileron Set-up (Please Help!)
BTW, Bullseye,
With your model and the existing connections, you can leave the lower existing work as it is. Simply take the upper horns and move 'em onto the top of the ailerons and you're going to have a very good rigging setup.
The stagger of the wings causes some of the problem, but provides part of that solution. After you've moved the top horn to the top of that aileron, plug in a connector wire and see if it doesn't make a right angle at both connections. That's what you're after.
