RCU Forums - View Single Post - Defiant MKII
Thread: Defiant MKII
Old 03-30-2006 | 01:57 PM
  #41
tschmidt
Default RE: Defiant MKII
Thanks David and Bob for your comments and weights. I've definitly have something to shoot for as far as weight is concerned.
Dave, The surface coat I used while making the molds is available from www.fibreglast.com and is a thick epoxy paste mixed 100 to 11(by weight) with its catalyst. You can also by the tints from there also. The surface coat is a better solution to using thickened resin although a lot of people will use thickened resin as a surface coat.
After applying the first coat of surface coat, I let it dry till its hard, but yet tacky (takes about 2 hrs) . I then apply the surface coat again, but work the first layer of glass cloth into it(I used 7.5oz cloth). After the glass cloth I followed up will 3 layers of fiberglass mat. This produced a mold of approximatley 1/4" thick.
I buy all my materials on line through: Fibreglast.com
Aerospace composites
The composite store (CST)
Also Aircraft Spruce Co. has a lot to offer in composite materials.
Hope this helps,
Todd
