RE: Beginer Help!
If its a futaba radio and a Align ESC you have to reverse the throttle direction on the transmitter and to program the esc you start with the stick at full throttle when you power up the esc, that should put it into setup mode.
You want soft start/mid timing/75 percent cutoff/non governor heli mode
