RCU Forums - View Single Post - CT5 Toe In
Thread: CT5 Toe In
Old 03-31-2006 | 11:39 PM
Timmahh
Banned
Default RE: CT5 Toe In
Bounty there is no BEST TOE IN configuration Per Say, only the BEST for the track or road conditions you are currently on. go to a new place with a differnt track setup. angles/ turns. surface. then your CT5 will need to be ADJUSTED to be the best for THAT TRACK.. so.... you can only set them up for each track. unless each place you run at is pretty much identical, then you ll need to make minor adjustments to acheive the best set up
hth
Tim
