CEN Racing This forum is to discuss all CEN Racing products.
CT5 Toe In
Old 03-31-2006 | 04:13 PM
Default CT5 Toe In
Can anyone tell me how to Toe in my CT5
Old 03-31-2006 | 04:32 PM
Default RE: CT5 Toe In
Please add the best Toe in configuration for the CT5
Old 03-31-2006 | 11:39 PM
Banned
Bounty there is no BEST TOE IN configuration Per Say, only the BEST for the track or road conditions you are currently on. go to a new place with a differnt track setup. angles/ turns. surface. then your CT5 will need to be ADJUSTED to be the best for THAT TRACK.. so.... you can only set them up for each track. unless each place you run at is pretty much identical, then you ll need to make minor adjustments to acheive the best set up
hth
Tim
Old 04-01-2006 | 10:58 AM
Ok thanks again
Tim, always helpfull
but how do I determine what is best for my track which is basically an asphalt with a small amount of sandy areas on an even course
