RCU Forums - View Single Post - SIG CUB BUILD
Old 04-01-2006 | 12:25 AM
khodges
Default RE: SIG CUB BUILD
ORIGINAL: bluebikerblan
The first thing I would do is move next door to khodges.
Thanks........I think. I've got a rental next door, it's available.
wilinfla, I use different stuff for different projects. On the L-4, I used oil-based polyurethane. I wanted the yellowing that it gives, so the color would come out a little darker and aged looking. I've been using Top Flite LustreKote lately, over latex paint on Solartex. It is compatible with both, and is the best fuelproofing I have used, but it is not compatible over some enamels and will make them wrinkle and lift. I have found that if you mist a very light coat over well-cured enamel, let it dry and then recoat, it will usually work, but experiment on a scrap first to see.
Sorry I didn't answer sooner, been out of town, went to Miami Beach for a meeting. Rough life, but somebody had to do it. Stayed at the Eden Roc on South Beach.
