RE: typhoon 3d esc
Well, i wouldnt say that but thanks. Where does your typhoon balance at? i read the balance point was 3inches from the leading edge, also 90mm. ive made both of those marks and mine is right inbetween. about 85mm.Which prop are you using? Im running the 13inch, I treid the 12 but it didnt have the pull out power with the stock battery. i havent tried the 12 inch with the lipo. I got the typhoon to practice for the passion 3d plane i got almost two years ago. And last summer I only flew about 10 times.It does take practice. Spring is finally here, I had the last 5 months to practice on my sim. Im a not a presision type flyer. i tend to wring it out and dou what ever comes to mind. I have no problems with using all stick travel when needed or otherwise.
