Update on Creek Extra
i took my back plate off and drilled a 1/8-1/4 off the center to give you access to be able to put a wrench on there. the rod run around the other side of the plate you can see were once you take the plate off. once installed i filled the 1/8 stub down level. hope that all makes sense....
