Update on Creek Extra
Mike,
You say that when you plugged one side of the muffler exhaust it ran rich- did you then adjust the high end needle? Blocking off part of the muffler will increase fuel pressure which will make it more rich so you should need to close the needle valve some at least and very possibly the low end needle as well. You may have already said this but where is your tank mounted?
