RCU Forums - View Single Post - Update on Creek Extra
Old 01-21-2003 | 01:40 AM
  #78
MHawker's Avatar
MHawker
My Feedback: (16)
Default Update on Creek Extra
That fitting in your pic is the part I'v already ordered (on b/o) from Tower. It sure does look like that shouldered hole is meant for a pressure fitting, though.
And since you've got to drill a hole (whether in the top left bolt hole or in this shouldered area), I'm not sure one IS better than the other. Unless there is a pressure or lack of pressure argument.
I've even had a guy at out field that said you can drill a hold through the mounting flanges on the engine between the two holes and get the same pressure.
Later.
