pictures
Hi Mike
I ordered the pressure fitting from Tower the other day and received shipping notice today.... The fitting was in stock so I hope you've got yours by now.
You told me you wouldn't mind posting pictures..... So here is my request.
1: Side shot of the tail section showing where your pull-pull cables enter the fuselage
2: Side shot of the cowling. Mine has so much down thrust that the side trim won't match when the spinner is centered? Because I have to tilt the cowl DOWN!
3: When you installed the landing gear did you have tow-in or tow-out. With the main gear installed (slanting forward) I've got a good bit of tow-out. Just curious!
I've got the Bisson Pitts muffler and it looks like I won't have much of a cowl left on the bottom side ;O(
BTW: I'm really interested in running just crankcase pressure without the pump as mentioned in one of the other posts.
Jim
