Update on Creek Extra
i use the cllear tubes u can buy from the hobby stores and i then run those down the length of the fuse and run my pull pull wires inside those tubes. this is very easy to do with the bottom of the plane open. sometimes i run lite ply and drill holes inside and run the tubes thru this and glue this down so that it never comes loose or moves. try this and you wont have to worry about a former being cut....
