RE: W.M. Extra 300 S
Shesha,
Was wondering if you are using FM or PCM and did you run into any interference problems? I've heard that if you run your antenna parallel to pull-pull setups it could cause interference.
Also, what radio are you running
On your DA, what size tank are you running and how long can you fly for. What prop are you using
THanks
