RE: Control Surface Linkage questions...
Tried most all of the systems but I just like the soldered clevis on one end and A threaded clevis or ball link on all the outside surfaces so I can adjust when needed without taking the plane apart. I also use A pull/pull rudder on all my planes, just because they are lighter and very easy to set up. It's mostly just choice and what has worked well in the past, they all work so go with what you like.
Bigger planes need better control systems as do stunt planes so it also depends on the plane itself.
