Good job on your rebuild. I am completing my Eclipse and have a question. It seems that there are no specs for incindence of the wings or stab in the instructions. I know the fuse sets the engine to 0.5 degree down thrust and 1.5 degree right thrust. Where is the zero degree thrust line referenced to? the canopy base? The plan calls for the CG to be on the tube, 30 - 35% MAC. What did you set yours to? I am using a OS 140RX, Hatori header and pipe.
