RE: First plane, 3rd maiden
the best way to fix it is with a heat gun. your blow dryer won't get hot enough. you need a heat gun. twist the wing with your hand then apply heat to the covering and remove the wrinkes you formed by twisting it. the wing will have less of a twist. if done right it won't hace a twist.
