RE: Tune pipes
Generlly speaking, I don't think you would want a tuned pipe in your general 3D setup unless you are able run run a very long header section. I also looked into this a few months ago and learned that you mid range will suffer unless you have room for longer header legnth. Your top end however will peak much higher. So....if you like to huck it on the deck.....I wold go with a Canister or Standard Muffs........but if you more of a pattern guy.....they a tuned pipe may be for you.
Neo
