...Diablo I havent checked TAMIYA USA so Im not sure...Probably NOT as no-one seems to be talking about it...Check it out and let us know :d
EDIT: TAMIYA USA has it up as 'Coming Soon'...Whatever that might mean...
http://www.tamiyausa.com/product/ite...oduct-id=58370
...Here is TAMIYA's Promo Blurb...
QUOTE..."This 1/10 scale 4WD buggy is specially designed to excel in off-road buggy racing. It features a mid-rear mounted motor and longitundinally mounted battery for optimum balance for jumping. Battery is inserted through the bottom of the chassis, eliminating need to remove body, which makes routine maintenance easy and quick. High performance shaft drive 4WD combines with suspension system featuring extra long suspension arms for improved stability and off-road handling.
High performance 1/10 4WD buggy chassis designed for off-road racing
4-wheel independent double wishbone suspension features CVA oil dampers and extra long suspension arms for improved stability and handling
Includes sealed diff gearbox indispensable for off-road running
Features full ball bearings
Includes 540 type motor
Newly designed off-road tires and wheels featured larger diameter and width, and new tread pattern designed for excellent running and control on hard dirt tracks
Tires: High Density Spike Tires K (4WD/Front, 62/25), High Density Spike Tires K (Rear, 62/35)
Wheels: Large Dish Wheels (4WD/Front, 62/25), Large Dish Wheels (Rear 62/35)
