RCU Forums - View Single Post - micro pump and ECU
Old 12-12-2002 | 03:25 AM
johnnyjet
Default micro pump and ECU
Jason
I am glad to hear the great results.
Johnny
“ Thats what I am doing on my Reaper. After taxiing back to the pits I plug in the battery, shut donw the engine and then switch on the starter motor to cool down the turbine. Usually takes 30 seconds or less to get below 50 degrees C. No more blower to haul around!
Andrew”
Hi
Andrew
Some of your earlier post is what got me going to the auto start front end.
What ECU are you using?
What start temps are you getting when you use the start motor only?
johnny
