RCU Forums - View Single Post - micro pump and ECU
Old 12-12-2002 | 10:56 PM
Woketman
Default micro pump and ECU
AJ, when I was using the excellent FADEC on my TJT 3000s (before going to TEMS full auto start), I was using a 4.8 volt pack and running a 28 lb thrust engine fine with it. Have you looked to see if you have a fuel restriction or too much 4 mm line?
