RCU Forums - View Single Post - micro pump and ECU
Old 12-12-2002 | 11:01 PM
Gaspar's Avatar
Gaspar
Default micro pump and ECU
Hello Andrew,
Ok, if you are happy with your setup, perfect. I only say that a mechanical regulator is a bit overkill, the ECU can manage voltages for the pump battery up to 10V.
From the safety point of view, your system is good, in the case of electronics fail you have a backup system to protect the engine.
Gaspar
