...It comes with TWO spur gears...The 'stock' one is 78t and is listed to be fitted as per instructions...The other is a big-ass 85t which is listed as 'not used'...Hmm...it will fit though...and the bigger spur will give us more punch and acceleration...Sounds like a better spur for bashing
...EDIT: The recommended stock piston for the rear is the 3 hole and the 1 hole for the front with stock springs and 900 oil...I will set the 2 hole in the rear and the 1 hole in the front with 300 oil and stock springs...Pump up the preload with some spacers and just hope that the harder springs wont be too far away...
...EDIT 2: The stock pinion is 26t so you can see that the gearing is QUITE different to buggies in the past...The 26t pushes the motor RIGHT to the side of the mount so there isnt really any room to go smaller
