RE: Can't Purge engine
is the needle set rich enough? i once had the exact same problem and it was because the high speed needle was too lean, but then again you said that the engine was running well. maybe there is something blocking the fuel from entering the carb? check for debris in the fuel line or cracks that let air inside the lines.
