I used one JR 8611A. and the plane will knife-edge-loop with ease. The cost is about the same as two servos and you avoid the issue of the servos fighting each other. I also added some support to the rudder-tray to handle the load of the pull-pull wire tension.
Regards,
Eric.
ORIGINAL: nuvarin
Is everyone setting up with the dual rudder servos?
