RCU Forums - View Single Post - Can't Purge engine
Old 04-04-2006 | 12:28 PM
125cchyperman
Default RE: Can't Purge engine
if you want to this is another way you can draw fuel to the carb. But it does get a little annoying after a while take off the air filter and stick yuor finger over the ovening then pull the pull start. It should take about 2 or 3 pulls to draw it from tank to carb. Just make sure no dirt gets into the carb.
