Hello, my name is david from Belize Central America
Q1. I just bought a 160, Kit came, however. Nosewheel fittings dont match pre drilled holes in Nose wheel Bay, support is glued in 1 way and the fitting is another?? Is this normal or should I drill new holes.
Q2. main wheels dont fit the metal work that came supplied seems centre hole in wheels 2 small? Again should I re drill them.
Also plans are appalling, where do the small chunk of Balsa go, one is shaped like a U and the other is a small block.
First time build, so i need some help please.
Also whats the best engine
s and servos for this kit, I need the lot. Experienced pilot, but first time on RC.
Cany anybody help
Thanks David
