RCU Forums - View Single Post - mini hydro!
Thread: mini hydro!
Old 04-04-2006 | 05:42 PM
CadillacDTS2001's Avatar
CadillacDTS2001
Default RE: mini hydro!
ORIGINAL: Matty_c
SWEET eyecandy but what happend to the cat you were building the one with the outboard?
Matty_C
well that white cat it is done and i went up to my condo with both boats
and i ran the mini hydro i had a battery and it went about 25mph
but the white cat boat is a literal rocket ,BUT!!!! i kinda messed up on the hull
OK so i put the white boat in the water and it is sitting with that aggressive stance!(pic) i have a 19 turn motor on 6 cells i hit the throel and bam it popes out of the water like it literal was just moving with the out drive in the water !!! then it flattens out but it seems to be that the boat is sticking to the water to much, almost like there is a big wing on the bow of it and is pushing it down ! also it is hard to drive cuz i want to roll on you!!! (my fault[] ) also i turned a corner at full till and compley rolled it and sunk so i puled it in dumped the water out and hit it again it poped out of the water like a jumping frog then flattend out and it was leaning to the side like it want to flip over on its side
but i got a speed pass and i estimated a fast 30mph eazy ! so i have to paint it and then i will get a vid of it and show you what i mean about it wanting to rool and flip on me !
ok so the mini hydro:
well it ran good but because i had a preformace motor in it, it coulnt rev up to speed in the water so it didnt hesitate to get up on a plane, wile moving at a 15mph pace it looked so stealth ! with the carbon fiber look it was like a missel! so i opend up the hatch and found my self with a COLD motor[>:][X(] and NO water in the hull !!!
so then i brought it back to shore and shaved down the prop a bit, i then put it in the water with a full battery and zoom zooom never seen a small boat go so fast ! like maby 25 mph i coulnt control it i turned just a bit and blam it went off in the directon !
i love the boat and i cant wat to see how it is with a BL and a lipo !!!!!
ID:	438918   Click image for larger version
