RE: C160 transall build
David you will have to drill out the wheels. Check the axel size. The front is different than the mains. My front bulkhead was also drilled 90 degrees off. Since I could not get in there to do the drilling I just made up a new mount from ply and epoxied it to the original bulkhead. Mine is about finished. I have installed OS 26 four strokes and just using standard servos. I used better hardware to replace the supplied stuff. Two stroke engines would be much easier to install but I love the sound of 4 strokers in twins. Anybody else out there flying this plane with four strokes? Any advice on ail and elev throws?
