RCU Forums - View Single Post - Another UCD3D engine question
Old 12-12-2002 | 05:34 AM
supertiger
Default magnum 120
if the magnum will fit with the engine cover on, i would go with it . I don't know how wide the magnum crank case is but my RCS 1.4 gas engine with rear exhaust fits perfectly on the stock 120 motor mount that comes with the U-can-do and the cover still fits over the motor with only a small hole on bottle to clear the spark plug. I would think the RCS crank case would be larger than that of the magnum 120 so it should fit fine.
Hay YNOT did you repare your U-can-do after the accident?
t
