RCU Forums - View Single Post - how do i lower idle speed??
Old 04-05-2006 | 09:25 PM
ehroof
Default RE: how do i lower idle speed??
First you have to make sure that the transmitter is in the neurtral position, then turn the small screw under the air cleaner in the front of the carb counterclockwise to lower the idle. if this doesnt work you will have to adjust the throttle linkage and collar nuts.
