RE: Question
Rule of thumb with most "standard" radios is that if YOU can see it, you are in range. Of course you may not be able to tell what it is doing because it is so far away nor make it back to the field. There are other radios (park flyer type) that do not have this kind of range. You need to buy the correct type for the plane you are flying. There is very seldom a reason for flying at the extreme ranges.
