RCU Forums - View Single Post - Range check
Thread: Range check
Old 04-06-2006 | 09:11 AM
karldaschner
Default Range check
Hi there guys,
Not quite sure if this receiver is any good - Greatplanes Electrifly 4ch fm. I have the same one in a Zagi that gives no problems, but I went and bought a brand new one for my new Mini Funtana. The funtana has a Axi 2808-24 motor in, Jeti 30A speed controller, Kokam pack & HS-55 servos allround with a Futaba 6EXA transmitter (also I used the recommended crystal - Futaba for the receiver). My problem is this: Wanted to do range check last night, so I walked with airial completley in (dont know if this is the correct way - a friend told me today that one can pull out the first section of the airial), and i was about 15 paces away, and the plane went nuts. But as soon as I fully extend the airial I can walk away till I can harly see the plane and it behaves fine?
Any comment will be helpfull.
Karl
