RCU Forums - View Single Post - Only one needle on OS .25?
Old 04-06-2006 | 12:37 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Only one needle on OS .25?
Xray,
It's hard to see in the picture, but is there any of the low end screw sticking out or is it broke off flush?? If there is a little sticking out you could try cutting a slot in it so you can use a screwdriver to remove it. One thing I would worry about leaving is that the original screw has a spring on it to keep the vibration of the motor from causing the screw to back out. I'm a bit worried that it might back out in flight.
Ken
