RCU Forums - View Single Post - Senior Telemaster ARF modifications
Old 04-06-2006 | 10:07 PM
ArCeeFlyer's Avatar
ArCeeFlyer
Default RE: Senior Telemaster ARF modifications
Just an FYI suggestion. If your going glow power, it would be a good idea to seal the covering seams with CA or something where any fuel will be getting on it. I have the same ARF. I don't know if they still use the same covering now as they did when I got mine in the early '90's. The covering on mine eventually suffered from terrible fuel creep, getting in between the clear outer layer and the yellow adhesive. I ended up stripping the whole plane and recovered it with Ultracote. It is a nice plane to cover with all the big flat surfaces. Good luck on your project. It should be a lot of fun.
