RCU Forums - View Single Post - 28% Edge540T
Thread: 28% Edge540T
Old 04-07-2006 | 12:37 AM
whoover619
Default 28% Edge540T
I have a couple of quick questions for the 28% Edge:
1.) How many servo extentions should I buy? 6? or 8 because of the throttle and engine cut? I would figure I would mount the throttle and engine cut close to the reciever anyways, am I right?
2.) Is there an easy way to mount the choke servo installation on the Zenoah G62 without buying extra parts such as a throttle arm extention? I ask this because the manual is a bit sketchy there and I would like to keep everything easy without having to go out and get extra parts.
3.) Should I buy two 6.0v 1000mah batteries or one 6.0v 2100mah? or does it not matter? How am I going to make the two reciever thing work out? because by buying two RX's, doesn't that mean they both have to split the signals that are coming from my TX and that would give me half the range, or does it not matter?
4.) Last but most certainly not least, what kinds of glues should I get... CA glue of course, but should I get thin, medium, and thick (gap filling formula), or can I just be conservative and get thin and thick and live a jolly ol' life? and I need epoxy I am sure but is there any suggestions to anything else I need or is that it?
