Two recevers are not nessacary on a 28%. as for extentions 2-24" 2-18" and what ever you need for the throttle and choke. Dont forget you need some for your batterys depending on where they end up for balance.
on you battery choice. two 1000 Mah packs in my opinion are not suficiant for this size bird. a single 2400 mah pack or two 1650 packs would be better.
as for glue. Thin and medium CA and some 30 minit epoxy. and gorrila glue for the hinges.
I wil let someone that has worked with the G62 comment on that part of the question.
Welcome to the world of the Bunny
ORIGINAL: weshooverrr420
I have a couple of quick questions for the 28% Edge:
1.) How many servo extentions should I buy? 6? or 8 because of the throttle and engine cut? I would figure I would mount the throttle and engine cut close to the reciever anyways, am I right?
2.) Is there an easy way to mount the choke servo installation on the Zenoah G62 without buying extra parts such as a throttle arm extention? I ask this because the manual is a bit sketchy there and I would like to keep everything easy without having to go out and get extra parts.
3.) Should I buy two 6.0v 1000mah batteries or one 6.0v 2100mah? or does it not matter? How am I going to make the two reciever thing work out? because by buying two RX's, doesn't that mean they both have to split the signals that are coming from my TX and that would give me half the range, or does it not matter?
4.) Last but most certainly not least, what kinds of glues should I get... CA glue of course, but should I get thin, medium, and thick (gap filling formula), or can I just be conservative and get thin and thick and live a jolly ol' life? and I need epoxy I am sure but is there any suggestions to anything else I need or is that it?
