RCU Forums - View Single Post - Senior Telemaster ARF modifications
Old 04-07-2006 | 12:46 PM
NM2K
My Feedback: (14)
Default RE: Senior Telemaster ARF modifications
ORIGINAL: MikeFreas
Due to the overwhelming generosity of Al Gutkin I will be up and flying in a month or so. I decided to start ANOTHER Telemaster thread to highlight the modifications I will be making.
1. Make new main wing spars to get rid of the dihedral. I'm going to need some input on the strongest wood I can get. I went to the local Lowe’s and they had solid oak, would that work?
2. Mount the rudder and elevator servos in the tail. I'm going to need to beef things up a bit but it shouldn't be too hard.
3. Bolt on wing modification. I'm not sure how I'm going to go about this on yet but I have some ideas.
4. Modify the cabin for another bomb drop.
5. Make another rudder with about 3x the surface area.
I had planned on recovering the model but the yellow is starting to grow on me. I'm going to have to try and match the color with some ultracote.
Thanks again Al for the gift. I had to keep my son from getting into the box on the drive home.
Why would you want to get rid of the dihedral? Are you planning on flying Masters Class Pattern with this model?
Some dihedral is your friend. This model isn't going to do decent knife-edge or point rolls regardless of how much dihedral it doesn't have, but dihedral makes for nice, smooth, straight ahead landings. Rudder to roll coupling can be your friend, especially when performing airborne tasks other than aerobatics.
I like your other mods suggestions.
