RE: ys engine
The F 120's did not have a low speed adjustment on the carb.. Low speed adjustments are done by making slight adjustments to the pressure reg. screw on the bottom of the engine. Years ago my local YS "experts" said the screw should be almost flush with the edge of the reg. housing to give the best low end mixture. I wound up running mine turned in a bit more but I had a good idle and transition there.
Steve
