ys engine
Old 04-03-2006 | 10:31 AM
Default ys engine
hi,, i just purchased my first ys 120 engine, i have read how to adjust the carb,, but i can`t seem to firgure out where the low end adjustment screw is,, or i`m just confused? its a f120 ys,, the engine seems to load up at idle,, any help thanxs
Old 04-03-2006 | 10:54 AM
MinnFlyer's Avatar
Default RE: ys engine
The low speed needle is on the carb opposite side of the throttle arm
Remember that it is an Air Bleed, so open it (CCW) to lean out the low end mixture
Old 04-03-2006 | 11:28 AM
thanxs mike,, now from what i can see in the figure its the small screw inside the throttle ,, opposite the throttle arm,, but not the needle screw? correct?
Old 04-04-2006 | 10:37 AM
my ys f120 doesn`t have a adjustment screw there
Old 04-04-2006 | 11:53 AM
Suggest that you go on to the engine manufacturer's support boards and ask the questions of Dave Shadel of YS who gives excellent advice.
Old 04-07-2006 | 03:03 PM
My Feedback: (37)
The F 120's did not have a low speed adjustment on the carb.. Low speed adjustments are done by making slight adjustments to the pressure reg. screw on the bottom of the engine. Years ago my local YS "experts" said the screw should be almost flush with the edge of the reg. housing to give the best low end mixture. I wound up running mine turned in a bit more but I had a good idle and transition there.
Steve
Old 04-07-2006 | 08:13 PM
http://www.ysperformance.com/
Old 04-10-2006 | 03:46 PM
hey thanks for all the advice guys i will check it out
