RCU Forums - View Single Post - Solder help
Thread: Solder help
Old 04-08-2006 | 01:42 AM
Kmot's Avatar
Kmot
My Feedback: (24)
Default RE: Solder help
I have a Weller 80w soldering gun
That's your problem right there, bud. Soldering [/b]guns[/b] are not worth the paper they came wrapped in. Throw it in the trash, and get a soldering iron. A Weller 40W soldering iron will be okay. But, if you really want to see what easy soldering is all about, get yourself a soldering station. A soldering station has a huge transformer that makes the soldering iron tip heat up almost instantly. And it maintains the heat even when you apply the tip to your work. They are worth every penny.
If you are using silver solder, use a liquid silver solder flux. Apply the liquid flux to the part. Apply silver solder to your clean and fluxed soldering iron tip. Now, apply the hot silver solder on the tip, to the flux on your part. Whoosh! Like magic, the silver solder flows into the flux and part and you have done the deed!
GARBAGE:
Minimum needed for good soldering:
BEST for soldering:
