RCU Forums - View Single Post - Solder help
Thread: Solder help
Old 04-08-2006 | 04:28 PM
RVM
Default RE: Solder help
I think I will just do this and make sure I don't overheat the torque rods. It sounds a lot easier.
ORIGINAL: CubNut
I use silver solder and a propane torch, keep the flame at one end of the joint you want to solder and as the parts reach temp it will draw the solder right into the joint. I use this method for attaching solder on quick links and it works great.
I hope this helps!!!
Anthony
