RCU Forums - View Single Post - 2ND Smith Miniplane build. Need advice to make it better.
Old 04-08-2006 | 09:14 PM
EscapeFlyer's Avatar
EscapeFlyer
Default RE: 2ND Smith Miniplane build. Need advice to make it better.
What equipment are you going to install onboard?
I changed the way the N-struts attached to the wings. the stock way always seemed to unscrew, and then the rod would poke holes in the covering. I'll post a picture in a little while.
My miniplane built heavy.-My own fault. Its on the upper end of 6.5lbs, but she'll still glide in slower than most low-wing trainers! GREAT PLANE bar NONE!!!
You can see my mini in my gallery icon.
