Saito 150 exhaust
Thanks for the suggestions guys! I tried Perf. Spec. but their elbow is 14mm on one side, and 13mm on the other. Won't work.
The inverted idea would not be that difficult as I have to replace the firewall anyway. (it's an Extra 300 not a Cub) I spent alot of time cutting that first cowl to fit the 120 indeed. The 150 will fit the same mount, and throttle links though. (I especially don't want to go thru that hassle again.) {yes it was a downwind deadstick with little altitude} I was concentrating on getting it
back around, and when I pulled back on the throttle, the onboard
system kicked in, and re-started! At this point, I was so shook
it had no choice but go in. Thanks again Stan
