RCU Forums - View Single Post - NEW QUEST
Thread: NEW QUEST
Old 04-09-2006 | 10:54 PM
  #266
RAD Dog
Default RE: NEW QUEST
I just got my Quest 2 and am in the process of putting it together. I have not assembled a plane before other than putting together my nexstar trainer which did not take much. I have read through all the previous posts and got a lot of great info, but I have some questions and I am sure I will have a ton more as things go together. I plan on making this a quality build and I will have to budget out a few things so this may be a slow build (also have to keep my wife happy with honey dos). I have picked up a YS 110 for the motor and I am planning on using Hitec 6975HB for servos on ailerons and elevator. I was going to use a metal gear for the rudder, but I am not sure which would be best and also what would be good for the trottle. I also was wondering if the nylon hinges are the best way to go or if I should go with an aftermarket type. The last question for now is with the fuel tank, is the stock tank OK and the instruction (which really are terrible) show the placement for the tank but I have a rib located there, so I take it that I need to cut out that cross brace on the rib and should I glue in a replace ment after the tank is in place.
Shaun
